weird wire
Just ran across a red wire behind the diagnostic cover on the drivers side footwell.It almost appears to be round romex! Looks like it might be 16/2 or maybe 14/2. The end is clipped neatly so I 'm thinking factory and it runs under the carpet towards the back of the car. Anyone else seen this on their car? I just noticed it tonight while trying to fix the dreaded 'battery drain' syndrome:( As always, any help is appreciated.
dennis |
Re: weird wire
could it be a amp/subwoofer control/power wire that runs to the trunk?
Re: weird wire
possibly a power antenna wire? does ur power antenna work?
Re: weird wire
Dennis- What you are describing does not sound like a factory wire. My best guess is it may be a remnant of a car-phone which may have been installed at one time. Additionally, I would check around for any additional wires that tap into you 12v/accessory wires as an aftermarket accessory installation done improperly will lead to a battery drain issue. Hope this helps. |
Re: weird wire
Thanks to all. Mike, I do have a remote alarm/start device but I disconnected it and still have a drain. Alternator seems OK. No internal ground. Time to start the process of elimination I guess. I think I'll track the red wire down just out of curiosity. It seems that it only does this during winter months. Thanks again for the help. Antenna is fine also. No amp/sub just factory. Will report back with the cause when I find it!
Re: weird wire
You can easily determine which circuit has a draw by pulling one fuse at a time and seeing if the voltage at the battery changes. If it does, then that is where I would start to look. I read here that if you have a draw, it will drop the voltage down at the battery a noticeable amount. Good luck. Electrical gremlins are the worst.
Re: weird wire
Re: weird wire
Thanks guys. thanks for the links. I wish it wasn't 3 below i'd be working on it right now. Suppose to warm up tomorrow to a whopping 20:)
dennis |
