problem with heat
heat stopped working all together was wondering where the thermostat is located on the svx any info/ pics of its location would help thanks
Re: problem with heat
The thermostat is located on the front of the water pump where the lower rad hose goes into the engine. There are two 10mm bolts holding the t-stat cover on. Drain the rad first, remove the lower hose, remove the t-stat cover, remove old t-stat, install new one with new gasket, replace cover and hose, fill and bleed coolant.
If you are getting no heat whatsoever, its much more likely theres a problem with the mix door or control system, or you are very low on coolant, OR your water-pump is toast.
A stuck open thermostat will still allow the engine to get warm enough for heat. |
And what does your temp. gauge read?
ill have the engine all warmed up and i have the temp set to 85 but its nothing but cold air
If the temp. gauge reads normal when driving the car, then look at the air mix door as Socal mentioned.
wheres the air mix door
Gene |
any pics of this area?
Don't have any pictures but here is the parts diagram from Subaruparts.com.
The mix motor is #2 on the bottom of the heater box. The mix door rods are #7 and #8. You might try giving them a nudge while raising and lowering the temperature and see if they will start working again. Also a power test to the electrical plug to see if a signal is coming from the AC control unit. http://i231.photobucket.com/albums/e...ner/heater.gif Gene |
