F/S Gold 1992 SVX 5 Speed
Year: 1992
Model: SVX LSL VIN: JF1CX3530NH100160 Manufacture date: Paint Color: Maya Gold Pearl with a light spray of colored Metallic chips. they change colors as the sun hits them. Interior Color: Grey Miles: 161,xxx Location: Fredericksburg 22407 Options: LSL Modifications:.... 2006 WRX 5 speed trans 3.70 ratio Dual aftermarket head unit kenwood door, tweets, and rear deck speakers JL 4 channel amp Battery in trunk relocate custom exhaust Eibach coil overs with koni inserts Powder coated calipers slotted rotors, red stuff front pads green stuff rear pads custom painted enki rims urethane rear swaybar link bushings STI engine mounts on modified svx brackets stainless steel brake lines Motorsports warehouse Alcyone floor mats LED bulbs in cluster with white face gauges LED bulbs in footwells and door puddle lamps small car clear headlights 5k HID headlight bulbs installed 97 grilled more mods I cant think of at the moment...will be updating. AWD or FWD: AWD Major service: ...Timing belt replaced @149,000 miles, October, 2007 done by Huck. At the same time: - cam seals - crank seals - cam plugs - timing belt - water pump - thermostat - bypass hoses & clamps - timing belt tensioner - accessory drive belts (Gates premium) Fresh Prestone coolant, 50/50 premix New accessory tensioner bearings, SKF 2RS - double seal - (both AC and PS/Alt) New valve cover gaskets and valve cover grommets, @ 152,000 miles, 12/27/2007. New temp sensor, 9/22/2004 New spark plugs (NGK Iridium) @ 120,000 miles New EGR pipe from exhaust manifold to egr block. Engine Condition: no problems, no leaks Maintenance Records: see above Transmission condition: great! Approx 35k miles on 06 WRX setup with new exedy clutch under 1500 miles on clutch. Glass condition: good. small but very minor scratching, all window guides replaced a year ago...stationary glass tinted 20% front windows 50% rear windows 35% Type of tire and remaining tread: Firestone wide ovals, varies...will get tread depths. Type of wheels: Enki...these wheels are LIGHT! Interior condition: Good. Body condition: Good! paint is less than a year old. Rusted areas were cut out and replacement SVX panels installed. Known defects or problems: On a rare occasion it still clicks when trying to start...It will eventually need a starter or ignition switch, everything else in ign. system has been replaced. pass window and sunroof is slow to close sometimes. Needs a rear wiper motor. Comments about the car: Over 12k invested in this car. I will be removing (or have removed) some of the goodies to bring the price down to a more affordable range. I am flexible on what the car will come with to adjust the price. this used to be Gsodonis's car...be advised some parts have changed and or been removed from this thread..http://www.subaru-svx.net/forum/show...t=speed&page=3 Asking price: $6500 I am selling because this car does not need any "real" work. For some reason I buy these cars and fix them then get bored with them, Guess im trying to keep as many alive and on the road as I can. I have 2 more cars to fix...one is at the body shop and the other is at my parents house...Im sure they (or one of them) will be for sale too when Im done fixing/painting them as well. I will always have at least one though:D http://photos-a.ak.fbcdn.net/hphotos..._3372279_n.jpg http://photos-a.ak.fbcdn.net/hphotos..._8133933_n.jpg I will take some more pics with interior shots this evening...its been raining here for a week:mad: |
Re: F/S Gold 1992 SVX 5 Speed
I just came to the realization that this used to be Michael Lai's car. (The original owner.) I'm shocked to see it in that paint color! Michael was a very active member back when the network was just starting, and was the host of the famous Midwest Meet.
Just like the car..you love it or hate it;) |
WTF is with everyone selling their cars? Did I miss the memo or something? I saw this car at the pumpkin carve. The color looks better in person.
It seems to be impossible to fully capture this cars paint...the pearl never shows on any of these shots. Ill have some interior shots tommorrow...I went to the u pull it junkyard yesterday. mmmm m fun |
Mike |
Wow....sad times :(
I can more than vouch for this car, considering that a most of the work was done by me (I had Huck do the timing belt and cam seals - credit where credit's due). Here was the list of mods and upkeep when Eric bought it from me. Year:1992 Model:LSl VIN:JF1CX3530NH100160 Paint Color: Ebony Interior Color: Gray Miles: 156,000 Location: (Knoxville) Options: Rear wing AWD or FWD: AWD Modifications: 5 speed conversion (see transmission details below) Alcyone silver hood badge New hood struts using the hood strut mod New trunk struts using the trunk strut mod Headlights, side marker lights and center waterfall grille polished and clear coated Painted wiper arms (all three) with Valeo Ultimate wiper blades Hella air horns Lightened Perrin aluminum crank pulley (1 pound, vs. 5 pounds) Stebro full exhaust with Euro resonator New muffler hangers @ rear Stebro muffler Mar, 2008 New custom Y-pipe, August, 2007 - limited 25,000 mile warranty (5 yr, 50,000 mile on stainless cat body and flanges) - 2 high-flow Magnaflow pre-cats (75305) - One high-flow Magnaflow 2 to1 main cat (75273) - All piping in stainless steel (not aluminized steel) - The Y-pipe wrapped in header wrap and painted with high temp silicone paint. All new exhaust manifold studs and new Subaru metal exhaust gaskets New PWR aluminum Radiator, Mar, 2005 - Motorsport Warehouse blue silicone radiator hoses - Stainless T-bolt clamps – no cheapo screw type clamps here ECU Tune 2v4 chip Grounding mod Ground control springs and Koni shocks Lifetime alignment at Firestone $15, 15 minute mod Rear sway bar bushings replaced with Prothane, urethane bushings Cross Drilled rotors with Akebono ProAct ceramic pads all around Stainless steel braided brake lines Rebuilt brake calipers, F&R (with Subaru OEM rebuild kits), 2005 Smoothed, polished calipers (casting roughness removed using a 4” hand grinder w/flapper disks) Calipers powder coated 2005 Chevy Corvette Victory Red. Matching keys (4) + one WRX STi stainless steel ignition key cut to fit SVX lock cylinders Black Motorsports Warehouse floor mats – with grommet and retaining clip mod: 9/10/2004 The very first WRX steering wheel conversion – but no airbag. Original SVX wheel w/good bag included White faced gauges with needle centers painted a matching white All dash bulbs (inside of the gauge cluster) replaced with white LED’s Nighttime gauge faces are blue. You can change this color to any LED available. Footwell accent lighting - blue LED New style Keyless Ride remote (red) + 1 good stock SVX remote Rebuilt retractable radio antenna with new Subaru OEM mast Major service: 5MT swap performed by PO. AC system converted to R134 Jun. 2007 by Earl Duff Subaru Timing belt replaced @149,000 miles, October, 2007 (Work done by Huck, father of the 5-speed conversion). At the same time, we replaced: - cam seals - crank seals - cam plugs - timing belt - water pump - thermostat - bypass hoses & clamps - timing belt tensioner - accessory drive belts (Gates premium) Fresh Prestone coolant, 50/50 premix New accessory tensioner bearings, SKF 2RS - double seal - (both AC and PS/Alt) New valve cover gaskets and valve cover grommets, @ 152,000 miles, 12/27/2007. New temp sensor, 9/22/2004 New spark plugs (NGK Iridium) @ 120,000 miles New O2 sensors: 10/20/04 New ignition switch (not the keyed ignition cylinder but what’s behind the cylinder), July, 2005 - This is the culprit that causes the infamous ‘my SVX won’t start’ syndrome - Car starts EVERY time New Red Top Optima battery, May, 2007 - 36 month direct replacement - 80 month pro-rated replacement Remanufactured Beck & Arnley 95A alternator, October, 2007 (w/2 year warranty) Replaced cam position sensor, August, 2007 Rebuilt driveshaft with new serviceable (greasable) U-joints, front & rear, Jan, 2008 Engine Condition: Excellent. Starts right away and purrs like a kitten No leaks of any kind (see last major service above). No missing or hesitation. No 5SP stall issues Maintenance Records: Yes - I have all documentation and receipts from 8/2004 - present Transmission condition: Excellent 5 Sp. WRX transmission (hydraulic actuation), stock flywheel and clutch, Front diff, rear diff and transmission fluids just recently changed August, 2007 All driveshaft boots good New B&M WRX billet short shifter and urethane shifter bushings @150,000, Dec 2007 Rebuilt driveshaft (new U-joints front and rear) @150,000 miles, Jan 2008 New STi Group N Motor mounts @150,000 miles, Jan 2008 New STi Group N transmission mount @149,000 miles, Dec 2007 Glass condition: Perfect window glass all around (no chips, no scratches, no cracks) with perfect 20% tint, w/limited lifetime warranty: installed 9/24/2004 All window switched work perfectly Type of tire and remaining tread: Set 1 (on the car): Firestone Wideovals (ultra high performance, summer), 225/40/18’s with 40 – 50% tread remaining Set 2: BF Goodrich Comp TA all season, stock 16” size – 50% tread remaining. Type of wheels: Set 1 (on the car): 18” Enkei RS-6 w/ Gorilla lug nuts, no curb rash. Set 2: Full set of four stock SVX wheels w/2 Full set of factory SVX lug nuts. Center caps are in great shape, color matches the rest of the wheels – no fade. Interior condition: Leather excellent – no rips, or tears, almost no wear marks. Treated with Lexol cleaner & conditioner 2X/year Good carpets New driver’s side door sill, Dec. 2007 Have stock, gray Subaru floor mats (decent) in addition to the Motorsports Warehouse Black ones Body condition: No accidents Typical misc small dings and chips Typical Paint - not perfect. Hood could use a serious machine buffing Typical rear wheel well arch rust - passenger side only Two rust bubbles, passenger door only Typical fading of clearcoat on both rear sail panels Paint chipping on leading edge of rear wing Known defects or problems: Cruise control switch – sometimes it takes a few tries to get it to stay on - have a good spare switch Rear wiper switch – doesn’t always work – have a good spare clock spring and combo switch assembly Typical sagging drivers side visor – passenger side is OK EGR pipe (from stock passenger side cast exhaust header to EGR valve) leaks. You can replace it or block it (pinch it) off Center console (armrest) button missing – have new replacement Subaru button Sunroof needs an occasional nudge to open, but works perfectly otherwise The before mentioned rust – I’m a mechanical perfectionist, so that has always been my focus. Huck has a replacement wheel arch panel from his spare car that I’m sure you can negotiate away from him if you try hard enough Front rotors could stand to be replaced – I have a brand new set of gold zinc plated (made in the USA) Power Stop, cross drilled rotors, F & R Comments about the car: Adult owned & driven, fanatically maintained, daily driver 2-owner SVX: I purchased it from Michael Lay (long time member & still occasional lurker of these boards) on 9/4/2004 - I have a photocopy of the Illinois title showing the SVX was originally registered to the Lai family with 2757 miles on the odometer on 10/24/91 Did I mention no leaks of any kind - rear diff bushings from Entsteele. This was for an upgrade – the stockers are still fine - new rear tail light seals - new Subaru center console (under the armrest) button - spare Subaru temp sensor Erics is obviously a perfectionist and took the SVX to another level altogether. If I had the funds, I would buy this right back from him. If the car still doesn't want to start on occasion, it probably just needs another ignition switch (not the key cylinder, but the switch behind the key cylinder. When I replaced it the first time, the problem went away COMPLETELY. Eric good luck with the sale. I like what you've done with her. |
To add to what I said... I last saw the car in the summer of 2002.
The gold metalic in the paint is spectacular though.:) |
They still make me smile!;) |
OK Ive been getting crap from multiple angles ...well not really crap, but the majority of it from the wife and my buddy John who helped fix her have been gnawing at me about selling the car. The big picture is I would be loosing too much car and then have to re-invest too much money to do it all again.
My decision to sell the car has changed. Can a Moderator please lock or delete this thread. My apologies to those interested in it. Stress has recently diluted my reasoning. |
I understand that life and times change and people move on. But lately it just seems like a trend. Glad to see the car is staying put. I hope to see you at more meets in the future.
Btw I know exactly how you feel about extra projects...i now have not only the svxs to work on, but a Fiero and a Cadillac. |
I'm glad you've decided to keep her - at least until I find the money to buy her back someday. ;)
I love what you've done. |
