HELP! 430 miles from home...
So I drive my SVX all the way to Reno from so cal.... makes it all the way no problems. It sits for a while, cools all the way down..... I start it up, its fine for about 60 seconds until i make a hard left turn onto the main street, where it stalls out and wont start. It cranks fine, I looked under the driver side timing cover, the belt is on and seems tight. I can hear the fuel pump come on with the key..... it just died after the turn and now wont start! Does anyone have ANY possible ideas on why this may have happened after a cooldown following a long drive? I wasnt stressing the motor when it happened.... was just driving normally turning left. Im stuck here until I can fix it :(:mad: Thanks
Re: HELP! 430 miles from home...
Sucks. MAF plug maybe?
I am betting on one of the sensors going... Crank Sensor...
Had that happen to me... same signs... everything fine one second... next its dead. -Sov13t. |
Any check engine light? I would probably check codes and if that comes up negative, would probably pull a line from the fuel filter and do a quick on/off with the key and see if you are getting fuel.
that sucks!
check all the connections, i would guess it is a sensor of some sort.... well, if all fails u might have a potential buyer here....;) my homebase is in auburn ca, about 100 mi from reno good luck! i hope you find your gremlin and get home! |
I would go with crank angle sensor, cam sensor, or temperature sensor. Mine was very intermittent until one day when it decided it will never start again. Then it was time to replace the sensor and all was well again :)
yeah, what Tim said...
-Bill |
Thanks for the replys you guys, ill check that stuff first thing tomorrow. It just had to be raining tonight so I cant do much now with no covered parking.
Crap, I wish I had seen this thread earlier! If you're still stuck in Reno Monday evening, I can probably get off work around 5 if you still need help! Not sure I'll be all that useful, but a second set of eyes might be all you need?
Thanks Scott, I might take you up on that. I got Dr apt around noon then im going to be all over this thing.
No new codes, would a coolant temp sensor keep the car from starting? Im going to test that when the weather improves a little, and remove the side timing covers and see if the cams are still in time with each other. Any other ideas? Popped off line from fuel filter outlet, fuel shoots out of it with key on. P.S. This sucks! |
At this point my car would just keep cranking but never start. WHen it did start the engine was flooded and I had some smokeage hehe. |
If I clear the old codes ive had forever, and keep cranking the engine, is there a possibility that it will help throw a code for the no-start problem? Thanks |
So the rain hasnt let up at all today..... 14 years in this town and it hasnt rained nearly this much BEFORE the day I needed to work on my car :rolleyes: From the gaggle of posts ive read on the subject, im going to test my CTS, then my MAF, then my CPS, and then im going to set it on fire and dance around it with a spear in my hand screaming YABBA YABBA YABBA.....
Also realized the front tires wore almost bald on the inner tread on both my front tires just from my trip here.... ball joints?? At this rate im going to get home with nothing but 4 rims, a steering wheel, and and my legs poking through the floorboard pushing me along..... |
