rear wheel wobbly
My right rear wheel is wobbling bad enough so that you can see it in the rear view mirror. Feels like it is ready to fall off.
I removed both rims yesterday, but can't really see, or feel, anything different between them. I can't move the wheel with my hands when the car is sitting still, but as soon as you start to drive it, the symptom re-occurs. I'm not at all familiar with this type of an axle. Could it be broken? |
Re: rear wheel wobbly
The wheel may be bent. I've seen many that have no obvious damage, but when spun on a balancer wobble like mad. Are you running stock wheels or aftermarket? If it isn't the wheel you may have a warped hub. My final guess would be that your wheel bearing has completely disintigrated, but that would include amazing amounts of noise. Put the car up on jackstands, put it in neutral, and spin the wheel by hand to see what it does.
Stop driving the car in the meantime. |
a broken axle would not be in the equation, The bearing in the hub supports the whole thing, Could a bearing be worn that much??? Could be warped hub.
I had a front hub warped from a big hole on the road. Good luck, Keith:( |
my typing speed always gets me there in second place!:lol:
Good advice, Crazy person! Keith:) |
It could be the bearing, I guess. Definitely not a bent rim. It's not like it's bent, it's like it's falling off! How hard are the bearings to replace?
did you check the lug nuts?
Bearing's are either not bad or horrific depending on the car. Mine were a complete horror show, it took a 6' breaker bar to get some of the bolts loose. I don't know what sort of winter you get, but if they salt the roads you will be in for a rough time of it. If the underside of your car looks new, then it'll be an easier time. There are several how-to's all over this forum about replacing the rear bearings.
Do you get a loud noise from the rear when the car is driving? If the bearing is bad enough for the wheel to be wobbling around it would be roaring like a jet engine back there. |
not real noisy
might be past noisey:lol:
Good luck working it out. If a bearing you could remove the bearing housing and have a new bearing-seals pressed in at an automobile supply that has a machine shop and reinstall the housing. **Always good to get a price before committing to take them the business! Otherwise, a dealer... ouch:( Keith:) |
when my saturns wheel bearings went out they didnt make a sound really, it just felt really bad while i drove and the wheel wobbled like crazy, no loud sounds though
Umm, I dunno if it would be the same on all SVX's, but my 92 has horrible rear bearings and it sounds like I'm crushing and grinding a ton of rocks in my trunk, you can't even hear yourself think over the sound of the bearings lol :p
