How do I get the rubber cam plugs out???
I'm trying to get the upper cam plugs out. Do they screw out or pry out?
What kind of seal is behind it? Thanks Jeff |
Re: How do I get the rubber cam plugs out???
just pry them out if you have a new one, look at it!
has a lip on it just pry the lip out and out it comes. (almost a wonder that they stay in):lol: There you go... Keith:) |
I think mine might be leaking. Can I just pop them out and put a thin coat of RTV on it and pop them back in?
I am about to change mine (hurry up DHL!!!) the drivers side is leaking, the passenger side is dry, changing it anyway. Changed the crank/oil pump seal today, that seal was a job to get out. Is the oil pump O ring the one at the lower passenger side of the oil passages? It's about the dia. of a quarter.:confused:;) |
The oil pump oring is the only oring when you take off the oil pump. All of the ones I have seen are blue. It is on the lower left.
I wanted to get mine back together tonight, so i'll try the rtv. |
I probably had them in place for about a year with no problems for about a year before I had to pull the engine apart for a head gasket job. When I did the HG's I used new plugs. |
Keith:) |
That's why it seems backwards when you're looking at it from the front of the car. |
My plugs had grey RTV on them. Is this a normal Subaru procedure?:confused: Dave |
If I had to take the cam plugs out, I would always put new ones in:confused:
Good luck with your project:) Keith |
