rear anti-roll bar
So I found a pic of the rear anti-roll bar, and also found that it's a 19mm.
Would anyone happen to have dimensions for the bar? Overall length? Arm length? Stuff like that? From looking at the pic it looks like the bar is VERY similar to what we've seen for the mini cooper rear bar, and I'm wondering if we can swap one on. |
I think SVXfiles has alot of those dimensions, may want to PM him if he doesn't notice this. I know there was one memeber on here that was making a new one, not sure if he ever finished it though. |
~ Chris |
Here's the 22mm rear bar I did with my machinist. Chromemoly heated to shape and then heat treated to bring the strength back up. Heim ends on the end links we fabricated to go with the bar.
http://www.subaru-svx.net/photos/fil...Ride/25579.jpg |
front bars are another subject, and I think would require my getting my hands on one to take some measurements. As it is, I've been thinking about the attachment to the strut body, and I have a couple of ideas for that. |
Ignore the right hand end link on the stock bar, I had to fabricate a new one when I bent the stock one in half during some early R&D work with a different bar:rolleyes: The stock end link is on the left hand end of the stock bar (wimpy, wimpy, wimpy...but then so are the front end links) -Bill |
Little better view of the endlinks for my 22mm bar...
http://www.subaru-svx.net/photos/fil...Ride/25583.jpg |
and yes, this is what happens to the strut housing mounted front end link attachment points when you put a 25mm, three piece front bar on....:eek:
http://www.subaru-svx.net/photos/fil...Ride/26810.jpg |
I'm going to be starting a project of restoring my SVX soon...sooner than later. I expect it to take quite some time to do, and for that period of time, I'll not be needing swaybars. If you'd like, I'll send you both the front and rear bars for your use in making some upgraded units. Hopefully I'll get some consideration on the price of your upgraded units to install when I put the car back together ;) |
As for the front - well, that's going to take some work given the endlink mount problem. I have a couple of ideas on this, but need to get under the car to check it out. Good thing Bret bought two of them. :) |
You are in Cincinnati! Mark5, (my Favorite Brother) lives there and has two SVXi on hand to measure. Or if it helps I can drop off a rear bar on Dec 29th as I pass through. With the remarcable improvements an anti sway bar can make I'm in! If you need me to drop off a front bar as well call me at 301-707-3437, just don't let anyone see the #;) :rolleyes: |
I am interested in both front and rear (especially front, if it is gonna be done also)... of course with a sexy price as always :lol:
I'd be interested in a bigger rear bar too :)
