'92 SVX parts car in NY
Car is now gone, thanks folks.
parts car
How far are you from syracuse. I interested in some parts like rear links, struts, drivshaft,and front control arm maybe interior, depending on looks thanks robert
I'll be pulling the motor out the week of halloween, thereafter any drivetrain/suspension parts you'd like can be removed. I can remove the parts, take pictures, then you can make an offer for what you'd want. Pickup is welcome if you'd want to make the trip. Make an exact list of what you'd like so I can remove/hold them for you when the time comes. I'm working on a first come/first serve basis on those big parts. -Regards |
How much for the instrument cluster (speedo, tach) shipped to 29651?
Could you post some pictures? I may be interested in the doors if they are rust free.
Regards |
I might hold onto that for the time being until I get the motor situated in the tube chassis and running, for testing the drive line and suspension of my kit car. I think there's a couple on ebay for like $10 though if that helps :) |
The transmission has been called for by a member as a parts tranny, thank you.
-Regards |
Lug Nuts?
I have aftermarket rims on my car with the :Gorilla Locks" on them. I believe I need the stock lugs to carry in my glove box in case I get a flat and need to put the "donut" spare on the car. I hear that the aftermarket lugs that I have will not work with the spare rim. Do you have any stock/oem lug nuts?
Stock lugs yes....replied and pm'ed you.......
The entire suspension(front and rear) and steering rack of this car seem to have been called for by a member. Anything else needed? Stuff that's gone: Cornermarkers 3rd brakelight Engine/Ecu/Harness/cluster Transmission Misc seat bolt covers, rear wiper components. Stock lug nuts Struts, suspension arms and links, steering rack. |
Anyone need anything from the HVAC assembly under the dash? Blower motor, A/C or heater cores....it's all there...
Dashboard is pretty much FUBAR as it looked like someone tried to rip it out for for some odd reason :confused: Steering wheel and airbag.....would have to be a pickup item only on the airbag as I will not ship explosives...... Window regulators(motors), switches, etc....they all work. All glass available except front windshield(big crack from rock) Entire A/C assembly is up for grabs.....pump, switches, condenser, evaporator, lines, etc........ Radiator/fans too...just haven't pulled them yet as I still need to be able to drive the car into the garage for engine removal.....very soon.... Any and all just make an offer otherwise core materials end on my scrap piles to be smelted down for material...... |
I'd be interested in the a/c system...
...so, please PM me with a price you think fair. Was the car running when you bought it?
Cheers!;) |
What parts do you need from the ac setup? I have pretty much everthying there, pump, brackets, hoses, condenser(I think), HVAC assembly under dash with evaporator and heater core, blower, control, etc. |
