My next mod
1 Attachment(s)
I just picked up my next mod today at the clearance table of Summit Racing. I'm going to put in an aftermarket single DIN CD player/receiver and above it where the stock tape player use to be will be these:cool:
Looks good. What are the 3 readouts? I can't read them on the picture. :o
I dont know that I would call it a mod... but it still looks good!
That addition looks good. :D :D
where are you tapping for oil and wateR??
Tom |
Locations
I just powered up the gauges to take a peek at them and they differ slightly from the picture and in my opinion are even better.:) The numbers are blue and there is a green bar graph above each gauge that goes up and down with the numbers. Friggin sweet!:D
When you get it installed, take some pictures of it. :)
I'll be the first to say I'm interested, if I can find some more information about them...is there any specs on them? Gauge ranges etc? Accuracy?
Ta, Matt |
Specs are: Volts: Range: 8.1-25.5 Volts Warning light will lite below 11.5 Volts Oil Pressure: Range:17-145 psi warning light will lite below 18 psi Water Temperature: Range:79-266 F warning light will lite at 210 F degrees. They are Summit racing part number SUM-800110. :) |
any pics of it being installed yet?
