Big Problem!
Alright, it seems I have a gas leak and the problem is I cant find it. There arent any puddles under my car or outside smells. The gasoline smell is inside my car and it has been there for about a week now and it only seems to get stronger! Plus, I am about to only get 250 miles in a 18.5 gallon tank...thats 13.5 mil.gal! And today my gas light came on at a 1/4 a tank, which is very unusual because it only comes on once the needle passes the E mark by a mile.
Is my gas gauge broken? I have looked under my car numerous times trying to find nething leaking and there is nothing (not even a smell) . I thought that since the smell is only on the inside of my car then i could of gotten it on my clothes when pumping gas, which has happened before, but now im worried. Any help like where someone else may have had gas leaks? |
Well you may need to trace the fuel lines from the tank to the engine. People have mentioned that the lines at the tank had rusted through and needed replacement.
remove your back seat and check for leaking near the fuel pump.
Check your connections to the fuel filter. Mine was seeping at the filter-out connection only under pressure, Strong gas smell at start-up, no puddles, no odor once moving.
dcb |
I work on car for a living and I have seen many cars that you get a gas smell more in the mornings. what I have found alot is when the motor is cold it will seep gas at spots where the lines go from rubber to hard lines. but only leaks when it is cold....it doesnt take much gas to smell it.....
i would also check the injectors, i ran into a bad o-ring on my #1 injector and it was leaking gas real bad, not to mention the drop in gas pressure
I found the leak and it is pretty bad! \The leak is coming from a line up in the frame of my car. Right underneath the driver side door. Any help? How could i possible fix this? This is probably why it smells worse inside my interior.
We removed the backseat and see the fuel lines, but the leak is somewhere between that and where we can see it from underneath. Pretty much in the worst spot possible. :/
Got her all fixed up. :) Thanks for all the help!
Good, your car is safer now :D How did you get her fixed?
We took out the back seat of the car and were able to pull the fuel line up through the hole in the frame. The leak came from a split in a plastic cover at the end of the steel fuel line and it allowed water, salt, or anything that causes rust to be stuck between the plastic and the line and thus rusting a hole in the line. So we cut the rusted fuel line and replaced it with rubber tubing and the only thing left was to link it back in with the other end of the line. Tightened all the fasteners and were all good :)
