-   Technical Q & A (https://www.subaru-svx.net/forum/forumdisplay.php?f=5)
-   -   power steering doesnt assist (https://www.subaru-svx.net/forum/showthread.php?t=35107)
Bxsvx 09-11-2006 09:43 AM
hey everyone, having a problem with the pearlie, sometimes the power steering works perfect, and sometimes it doesnt assist at all, like its manual steering. I saw the steering light, I should check the codes, but today it had no light, just stiff. Can I transfer over my fwd LS pump and sensor or it wont fit? I have a 92 lsl, and i know those are speed sensitive if im correct and the other ones are engine speed sensitive? is it the sensor or pump? :confused:
SSSVX 09-11-2006 03:11 PM
Do you have enough fluid in the PS pump? Do you have any leak? How do the belt and pully look?
Bxsvx 09-11-2006 04:07 PM
it has fluid, its sorta brownish, i never changed it, also no leaks. belts are in good shape and tight. I checked for codes, because i saw a steering light, and nothing comes up, it is the same connector as the engine one correct?
svxfiles 09-11-2006 06:45 PM
First, take a new turkey baster and siphon out all the TRANSMISSION FLUID in the P/S reservoir, and refill with fresh stuff, then have a beer.;)
Drive it for a day and repeat!
(including the beer!)
Do it again.
Do it again.
(This time have two beers!)
What were we talking about?:confused: :)
Bxsvx 09-11-2006 09:09 PM
lol Tom ur crazy, man if I were to drink, I think I would of passed out at Toms house, ur a trooper when it comes to drinking lol.
on another note, Is there a way to flush it once? like leave a hose open and let the car run while i keep filling? did the dirty fluid clog something? to make the steering work sometimes?
svxfiles 09-12-2006 04:50 AM
You would not be the first!
(Jason?)
You do not want to let the system run dry....
Dirty fluid can make the steering hard and inconsistant.
dcarrb 09-12-2006 06:15 AM
I'll second the turkey baster fluid change. The power steering on the SVX I recently bought seemed to have low-speed dead spots, and the fluid looked rather like beef roast au jus with chopped onion bits. One change of the contents of the reservoir (with a dollop of Lucas additive) and I've noticed nothing unusual since.
I don't know if grungy fluid might explain the PS warning light, but hey, it obviously needs changing anyway, so that's a good place to start.
dcb
Budfreak 09-12-2006 08:33 AM
(Jason?)
:eek: I didn't pass out, I just puked on your basement floor.:D:p:rolleyes:
Bxsvx 09-17-2006 10:36 PM
ok i flushed the power steering system, what a HUGE MESS!!! anyway it feels more responsive, like before it was tooooo easy to turn, now it has more of a response. im guessing that since the fluid has more thickness to it and its not worn, it has more friction(does that make sense?:confused: ). but I still feel it is a intermittent electrical problem, because the steering light comes on and off. Is there a relay that controls the electorinc part of the power steering? anyone have a wiring diagram that I can trace out the steering wiring?>
Earthworm 09-18-2006 02:00 PM
What error code are you getting?
Bxsvx 09-18-2006 04:26 PM
thats the thing, it lights up steering, i insert the blue wire to the port and no codes, its like it magically erased itself. am I using th correct connector, is it the same one as the cel self diagnostic connector. Theres a small black one, a long black one and a yellow connector. prong 2 on the small black one was for the cel, so i tried plug 7 for self diagnostic and nothing came up, i tried prong 6 and then prong 5, nothing :confused:
Earthworm 09-18-2006 05:23 PM
Yes, it's the smaller of the 2 black ones.
Bxsvx 09-20-2006 02:01 PM
ok it broke down again, what is up with this intermittent problem? im gonna trace the wiring friday and see if theres a loose connection. Will I find a relay connected with the steering harness? damn this problem :mad:
Bxsvx 09-21-2006 08:35 PM
bumpeeeeeeed
Bxsvx 10-06-2006 03:54 PM
ok I put in a new pump and released all the air in the system, still nothing. grrrrrrrrrrr, im pulling my hair out!
