-   Technical Q & A (https://www.subaru-svx.net/forum/forumdisplay.php?f=5)
-   -   Twin turbo set up (https://www.subaru-svx.net/forum/showthread.php?t=32117)
SVXfan01 03-15-2006 05:34 PM
Twin turbo set up
So if you were to run twin turbos, would you need two turbo boost controllers? Or could you run both from one?
svxsubaru1 03-15-2006 06:03 PM
It depends on how you have the intake plumbing set up, and if the turbos already have an internal wastegate or not.
To be honest from how you wrote your message it sounds like you need to do some more reasrch on the basics of turbos. Its easy to find info from google.
Phast SVX 03-15-2006 06:10 PM
either way you oly have one boost controller. You must realize that thewastegate controls boost, the boostroller controls the wastegate.
svxsubaru1 03-15-2006 06:11 PM
If theres two internal wategates then theres two boost controllers.
Phast SVX 03-15-2006 06:15 PM
find me a setup which runs 2 boost controllers! you dont want to run 2 boost levels into two differnt cylinder banks....
oab_au 03-15-2006 06:27 PM
Phil means that one controller can run two wastegates.
Harvey.;)
