Racing seat and harness are in!
New racing seat and 5/6 point harness are finally in! Total weight is probably about 5lbs less than the weight of the stock L seat that was in there as the harness isn't exactly fleet of foot. Took me quite a while to figure out how to secure the bracket for the rear. Up front I simply cut open enough of the mounting tunnel that is there to get a wrench in to tighten the nut. Will have pics once I figure out what's wrong with my wife's digital camera. Just sitting in it now makes me feel a little clastrophobic. It definately keeps you in place!
The tranny is totally bolted in and waiting for the rear dif to arrive before she returns to AWD tomorrow evening. I CAN'T WAIT to see what the H&R WRX springs do to the ride height and all. Have only been able to speculate for the past week. I think the front will lower a bit more and the rear should stay about stock but we shall see! |
5 lbs lighter? What seats did you get :confused: Mine weigh half the weight of two seats.
Read grasshopper, read. I said the seat and harness weigh about 5lbs lighter together than an L seat! It is your runn of the mill Summit Poly buggy style race seat. It and the brackets weigh a good bit less than 10lbs. The harness itself is like having a cinderblock on your chest. Good thing I no longer smoke! :D |
What gears are you running this time?
I have more 3.545 rear diffs, without the LSD, than I need. :rolleyes: |
The 4.11 rear is back together with the LSD and sitting on the desk of this Holiday Inn Express the company has forced me into all week :( It should be attached back to the car this weekend if Ben can find the bolts that hold it there :rolleyes: otherwise maybe some plumbers strapping and wire ties will be holding it in place :eek: :D |
2 nuts, 2 long bolts, 4 short bracket bolts,,,,,,, But ya know, 1 nut 1 long bolt, and 2 short bracket bolts would be lighter... :)
:rolleyes: |
HHMMmmm,,,"The first rule of racing is,"Whats behind you does not matter..."
Do you still have those three heavy mirrors? ;) |
Dave/Ben,
You guys are having waaaaaay too much fun! :D :D :cool: -Bill |
And the downside is,,,,,,,,, JUST KIDDING!!!! :D :D |
So what is behind u doesn't matter?? What if it is the rear stumbling across the course??? :D
I guess then it become your rear that will be in for a hit :D Tom |
did you have to make alot of mods to the seat bracket? I was looking at putting in WRX seats with stock brackets, but didnt want to buy anything until I knew if they would fit.
