I tried doing this on Yahoo, but the post quickly got buried. A few people responded, but not enough to make a meaningful set of data. Maybe this will work better, maybe not.
Please select the option that describes your car. Please do not post replies to this thread, just mark the appropriate choice. Owners of 95-97 model year cars, check Transmission Failure Rate Poll, 95-97. If this yields anything that makes any sense, I'll try adding something about mileage, too. |
Boy this thread is an oldie.
Haven't had any tranny woes--knock on wood--since I bought the car, but not sure on the history of it |
Tranny
My 92 tranny was replaced prior to me obtaining her. I think it was around 65K will check the records. And I am currently at 145K and going strong.
thanx Wayne |
I just looked for the 95-97 tranny failure poll and could'nt find it. Where did you put it? :confused: I feel that I'm being disenfranchised (and I'm not even French ) just like those voters in Florida. :D Larry III:cool: |
Hmmmm. I'm somewhat at a loss, here. It is obvious that my SVX has had the original tranny replaced. So, there's one failure. I checked with SOA when I first got the car. There was no tranny work during the warranty period. So, if the last transmission was the *Second* transmission in the car, and since it failed, would be the "Second" failure -- even if it was a Legacy tranny. I don't think that should count, since the Legacy tranny wasn't made for the car -- am I just rambling and babbling here? I think so. :confused:
Larry - don't look at those posts until you've found them yourself. ;) |
I hadta change the pull down at the bottom of the screen to "from the beginning." then sorted by date in acending order. lotsa old stuff in there
In the past 30K miles I have no failures of the front wheel drive but the rear wheel drive isn't working. But it may not have been working when I got the car. Most likely. I know it was replaced under warantee in Brooklyn NYC after about 3k miles and I think it was rebuilt around 43k miles. So is that no failures while I own it or 2 and a half for the life of the car?
