water in trunk
i am not sure what the problem could be. when it rains, i get water inside my trunk, where the spare tire sits. there doesnt appear to be any cracks, and the trunk and carpet are not wet at all. just wondering if anybody has any sugestions or has this problem
thanx |
Re: water in trunk
I'm guessing you've already gotten in the trunk, with a flashlight (drop the rear seat to make this easier :)), and had someone hose water on the trunk to make sure your gaskets are not failing. |
Re: Re: water in trunk
Harvey;) |
Re: Re: Re: water in trunk
Shhhhhhh, Harvey. I'm trying to give his friends a great opportunity. ;) :D |
Just had the same problem this morning when I had a flat. What should we do then?
Replacing the antenna hose is easy. Just pop out the trim on the left (driver's) side of the trunk, look in with a flashlight, and see if it's where it's supposed to be. It's obvious when it's out of it's receptacle. The gasket is also easy to replace, if it's the culprit. BUT, if it's the moonroof drains, it may involve removing the headliner, something I, personally, wouldn't want to get into. |
Re: water in trunk
I was getting water in the trunk through the plastic plugs right below the tail lites, I sealed them up with RTV and havn't had anywater since. Also if it was the antenna or sunroof drains the water would be filling up off to the sides behind the wheel wells not in the spare tire well, right? I'd also check to make sure it's not the tails light seals.
I've never seen this leak, but what about the path around the base of rear wiper blade? Wouldn't it drip down into that area of the trunk - of course the carpet would have to be wet too.
Plastic plugs below the light clusters was the problem in my case. Silicon seal around it solved the problem
Can someone provide a digital picture of these plugs? I opened my trunk lid and didn't see anything that obviously looked like plastic plugs. Thanks. -Bill |
If you open the covers over the tail lights for changing the bulbs you will see a big oval plastic plug right below the tail lite, you might have to pull out the trunk liner panels to get to/seal them.
Thanks...I'll have to take a look tomorrow - assuming it isn't raining again:D
