How to run wiring to door speakers?
Hey, I'm trying to install my door speakers, and I'd like to use better wiring. Anyone have any tips? I assumed the rubber 'wire cover' that goes between the door and the chassis would pop out, and it DID on the chassis side, but on the door side it has this big long rubber cone type thing that's all electrical taped to the loom, so you can't really snake a wire through it.
It's annoying. Anyone have any tips???? Thanks! = Rob |
I personally dont think it's worth all the extra time and stress. I heard using a hanger works but its kind of tricky. What gauge wire are you using?
Most people generally cant tell a difference, and most likely theres not that much power going to the speakers that justify using better wire. Good luck though if you still decide to do it. |
I used a coat hanger.
Mike |
Actually I read somewhere that most people can't tell the difference between monster cable and chicken wire :cool:
I'm not an audio guy. The reason I wanted to run wire into the doors was that I bought a component set, and it has crossovers. Hence, I need to get the wire FROM the crossover TO the door speaker. Anyway, I ended up just puttnig a tiny slit in the rubber boot thing, and pulling the wire through it. >shrug< it works.
- Rob |
I always find it funny that people love to take cheap shots at those who appreciate good audio equipment.
It's similar to people who make fun of those with an interest in fast, rare cars. :D After all, anybody that spends money on a car, especially an older, problematic sports car must be an idiot, right?? It's only transportation, after all! Only fools drive nice cars because we all get there at the same time. ;) :D :D I assume you see my point... audio equipment is a lot like an SVX. Those who get it, get it... and those who don't get it simply never will. Granted, most average Monster Cable is crap. You really do have to spend a lot of money to find something that sounds different, but it's out there. Even "entry level" companies like Monster Cable make some decent products, in their M-series line. I'd love to bring any of you over to my house, and we'll do a test where we listen to the same piece of music, first on my 2 inch thick teflon coated Straightwire Crescendos, and then on some chicken wire, and we'll see whether anyone can hear a difference... :D :D |
re: let me know when.
let me know when Porter. i want to hear the difference.
<Harry runs to home depot to pickup a spool of chicken wire.> |
my brother installs six-figure high-end home theater systems and he has tried to prove this to me, also. i didn't hear a difference. :rolleyes: i guess it might be like spending a couple thousand dollars on your car to gain an extra hp or two....maybe. |
In order that I may comment further would you please answer the following questions with a tabulated reply to save confusion, using words of exact and specific meaning. (1) How is it that a manufacturer alleged to be honest and reliable sells only, Òsome decent productÓ, the assumption being that the remainder is rubbish and how does that stack up against their claims of quality in sales promotion material ? (2) Does 2 inch thick mean 2 inch diameter which is what one normally take from such a statement and if not, exactly what is measured and in what unit and what dimension ? (3) Please confirm that Ò Crescendos Ò is a brand name for speaker cable and that you are talking about cable forming a circuit of less than 10 ohms impedance between an amplifier and speakers. (4) What is the exact reason for teflon coating ? (5) Why is it an advantage that the wires are ÒstraightÓ ? (6) Have you actually tried substituting some common garden type of wire, with an adequate cross sectional area, by way of experiment ? (7) What evidence can you put forward that is based on scientifically proven fact, rather than here say, assumption, presumption and your own or others opinion influenced by marketing hype. |
i guess you didn't know that electrons prefer to travel in brand-name designer cables. the teflon keeps the electrons from sticking to the insulation. :D |
