Loose strut nut
I have had a rattle coming from the rear drivers side and just checked the nut that comes into the interior where the speakers are. Sure enough the left rear nut (17mm) was loose. The right side was tight. I turned it but it did not tighten. Just spinning the whole thing. I assume I have to hold something under the car to get it to tighten. Anybody had to do this? When I first had my Koni and lowering springs put on I had to take it back and they tightened it but not sure how exactly how he did it. That was years ago. I was ready to order new rear upper mounts. Maybe I don't have to. I want to get this tight and check the noise again. Any advice on this appreciated. Thanks.
Mike:) |
Re: Loose strut nut
On both stock struts, and Koni's you have to hold the strut piston shaft from turning with an allen wrench.
Re: Loose strut nut
Re: Loose strut nut
For $20 this makes it easier;
http://www.harborfreight.com/21-piec...set-67974.html Plus it's handy is other places also, and it's not too hard to find a 20% coupon for HF. |
Re: Loose strut nut
Got one from sears for $40 :(
Re: Loose strut nut
Re: Loose strut nut
The sockets have wrench flats on them, much like a spark plug socket. The ratchet is a ratcheting wrench of that size.
Re: Loose strut nut
Re: Loose strut nut
Re: Loose strut nut
Re: Loose strut nut
Yes. I need to find more occasions to use them. I' waiting for my everyday set to poop out.
Re: Loose strut nut
Thanks for all the reply's on this. I tried to tighten it using vise grips on the socket and an allen wrench holding the stem in place but the nut would not move. I had a very tight hold of the socket but it would not budge. Maybe the threads/nut need to be loosened with something. Maybe a shop would have better tools to do this. I'll call and see. Thanks again.
Mike:) |
Re: Loose strut nut
Blue Thunder, do you have stock struts, or Koni's?
Re: Loose strut nut
Yes sorry for the delay. I have Koni struts all around. I took my car yesterday to a shop so they could get it on a lift and check the rear struts. They definitely said that the left rear upper mount and the rubber piece below it are shot. He moved the wheel up and down. I guess I am resigned to get new upper mounts. I have another question. I went to 1stsubaruparts.com and can get each one for 71.00. They have an illustration they're and the picture shows the upper mount and below it the upper back. Is this the rubber piece I need? Do I need to order it separately? Also I read on another post that this rubber piece may have sat on a shelf for a long time and it may not be in good shape. Is OEM the best way to go for replacement? Any feedback on this appreciated. Thanks.
Mike:) |
Re: Loose strut nut
Keith:cool: |
Re: Loose strut nut
Re: Loose strut nut
Of course both auto stores near me did not have a 17mm with hex flats...
But I was able to use my electric impact wrench using a 17mm impact socket to remove the nut...then after starting the nut after swapping out the spring and mounts, I loosened the spring compressors just a bit for pressure against the mount, then took the impact wrench and finished tightening her up. |
