Got CEL??
What are some proceders i can try to get a check engine light?? for example: smash throttle, go 80 mph, ect.
ive got some wierd problems but cant get a CEl, i need something to use my new obd2 reader on :D |
Wow..........
Hit something with a hammer. The MAF is pretty hit-able.
yeah the MAF is a good one and I've got one to sell you for after
only reason i ask is because i need whatever it is that is not working properly to send a CEL. when i used to work at the mazda dealer the techs would fix a car and mash the hell out of it to see if they can get the CEL to come back..... some reason my problems nearly go away when im on empty :rolleyes:
If the CEL blinked at any point there may be a code stored. The light doesn't have to be on to indicate a stored code.
woah, you don't need to beat on a car just to get the light to come on... it just needs to be driven under certain rules.. mostly:
start with low tank of gas, let it get up to op temp, drive 5 miles at low speed, fill up, drive 5 miles at high speed, start car again after it cools down. every car has different rules that trigger th IM monitors... driving it like hell only hurts it though, doesn't help to trigger them and throw codes. |
my obd2 reader says there is no codes... its also showing that my ecu isnt scanning my cat converters, and my egr valve... i drove around for like 10 mins and it still hadnt took readings from those 2...
hmm, misfiring at accel. then it also misses at cruise when in 4th gear.... id like to try to get a CEL by driving in 4th but it shaks the car so viontly that im afraid something will really go bad!!:o
Sounds like a MAF to me if its almost stalling.
Maybe all that rallying did you in. :o |
no, not the maf, i already tried a good one on, no diffrence...., o and it doesnt stall, it just mises...
Maybe bad plugs, or coil packs
could just be their time too though |
...Maybe washed the engine bay recently? Them pressure washers get water EVERYWHERE. |
if u want a CEL just unplug something... Off hand an 02 sensor would work nicely. As for your miss, I would imagine the coilpacks are doing it... Try testing each cylinder to see which is missing by removing the fuel injector clips. If you remove cyl 1 and the idle gets worse, plug it back in and move to the next one... and so on, until you find one where your idle stays the same, thats the cylinder you are having trouble with and work from there.
Tom |
yes ive used this procedure before, but the car isnt missing at idle, so wouldnt unplugging any of the coils make it die?
not the coils the fuel injectors... But I wouldn't drive with one unplugged... I would check your timing belt though to make sure everything is aligned properly
Tom |
